What you may especially want to look at are "analog switches." In the original CMOS 4000 series there's the 4016, 4066, 4053 and a few others - you should learn about these mainly for when you see then in older equipment. There's the newer DG4xx series made by several makers that's much better in every way - separate digital interface, analog switching up to +/-15V, lower on resistance, faster switching, all at a "moderately" higher cost.sircletus said:... digital control of analog circuits.
There are classic analog circuits such as full-wave rectifiers that use signal diodes around op-amps to do the switching, but if you really need high precision with such a circuit, forget the diodes and use a comparator driving analog switches.
The Art of Electronics mentions this DG series.
