I would like to switch the current setting Resistor in the LTP (by channel switch) in an el84 amp
1k2 for "voxish" sound and 470 for overdrive channel.
So just tried to "switch" a 1k parallel to 1k2 with an OPTO-Mos (Solid state relay) - it plops (as expected)
Not loud but unnoing.
I would like to avoid using Vactrols because of "floating" on-resistance.
What would be the best way to mute the amp in this case?
Will it work to connect the el84 gates together (using second opto-mos)?
Any other suggestions?
Regards
dimashek
Regards
dimashek
