Anybody got DBX 160 pcb over lay they would care to shre with me ?
on last page of this cal manual theres a basic layout with transistor and trimpot placement
https://www.dropbox.com/s/osy2m1p4lcc3glz/dbx%20160%20calibration.pdf?dl=0
  • dbx 160 service manual.pdf
    1.7 MB
those dbx are usually easy to repair, common problems i've seen so far is the ota in the rms can failing and also cold solderings on the vca and rms can.  the vu meters are also going bad quite often
dude24 man thanks for that the diag at the bottom is useful.
The problem I had is the breaking up that you get.  I reflowed all the usual suspects but the - PSU rail has gone dowm now ....... just trying to work ou which transisitor is which so that diag is useful.
I had a dbx 161 with -power rail not working. wound up being a shorted opamp.  there are links on the  -/+ rails from the PSU , lift the links and see if you get your rails back
    154.6 KB
