anyone knows where I can make a type plate ? Federal 864
andre tchmil
land of chicon
need a simple type plate for my federal 864.
a good example can be seen here : http://www.ebay.com/itm/Federal-Signal-Corps-Amplifier-AM-864-U-Audio-Tube-Compressor-Limiter-/121404030204?pt=US_Signal_Processors_Rack_Effects&hash=item1c443e7cfc
Press-and-peel mask. Aluminum sheet. Acid-etch.
Snag that image. Clean it up really good. Make a negative. It may have to be reversed? Print that image with a laser printer on a page ripped from Playboy or other very-slick magazine.
Get your aluminum VERY clean. Tape the laser-print ink-down on the aluminum. Apply a hot clothes-iron for several minutes, so the laser toner melts onto the aluminum. When cool, soak the paper off.
Study StompBox forums for metal-etching techniques. The etch will eat the aluminum where you want black. You want a fairly deep etch.
When etched, flood black paint in the etched areas, let dry, sand the un-etched areas clean.
Use a stamp-set to stamp your serial number.
