IIRC from a previous post, yes.ilfungo said:...the colors are correct on the PCB than API 2503?...
Did you parallel the primaries on the 2622? I forget what Bob's boards are set up for in regards to the input trafo.
This probably would not be your problem but if you have old, original 2503's some of the leads can be very faded and throw off your lead color scheme.
