JW
Hi folks,
I'm still learning, but I gather from reading that all the parts in regard to feedback circuit and the volume control are intricately related (in an API 312)
I have an input transformer from a PM1000 that I wired at 150ohm:2.7Kohm, and am also using it's 1:1 600 ohm output transformers.
Since this is a lower stepup, I dialed in gain to the same as a 312 I built from the usual CAPI/EA parts by adjusting the resistor on the way to the volume pot. In the 312, this is 200 ohm. I needed to adjust this to 37ohm to get the gain I wanted. A quick listen didn't reveal audible oscillating.
But my question is, to what extent should I adjust the other parts to maintain the same lo pass and hi pass filters? Or is this possible?
I can run a sweep but I'm limited by my converters in regards to seeing above and below 20Hz-20K.
My parts currently are:
feedback: 120pF/20K ohm
series resistor: 37ohm
series electrolytic: 470uF
volume pot: 22K
Am I correct to think as you lower the series resistor, the -3dB upper knee of the lpf goes down? So, I need to raise it back up by adjusting the feedback cap? But up or down? Yamaha uses 47pF here. I can't see where it is anyway by testing.
So I guess I need some math hand holding.
volume pot: 22K
