This question is related to a specific project I'm working on but is more of general basic question on figuring multiple corner frequencies in a 3 stage tube circuit.
The circuit is:
http://www.jlmaudio.com/au300mod.gif
Tube substitutions are V1 & 2 = 6SL7 V3 = 6SN7 All other circuit values stock except for sub of 3K cathode resistors on V1 & V2. OT = 20K:600 pri 11.4H Leakage ind = 52.26mH rated 30Hz-15KHz. Input transformer 150:20K rated 30Hz:15K
So far I've got low corner figures for Cc of each stage and the output transformer as well as high attenuation figures for each stage. What I do not know how to do is add them together to get a meaningful figure for what the expected overall response will be front to back with iron included. I'm ignoring the feedback for a moment to simplify things some. The text I'm using shows an involved graphical method for doing this which at the moment I don't understand any better than my attempt here to add them another way.
Lo response
Input transformer: assumed spec @ 30Hz
V1: .05uF/~600K = -3db @ 5.3Hz
V2: .068/~600K = -3db @ 3.9Hz
V3: *not sure on this calc - 4K//10K = 2857r -3db @ 39.9Hz
Hi response
Input transformer: assumed spec at 15KHz
V1 & V2: 45K//120K//560K = 30.9K stage gain = 22.2 30.9K/78.36pf = -3db @ 65.7K
V3: leakage inductance 52.26mH , 4.9K measured impedance for each half of pri winding = -3db @ 15K
So, lots of roll offs - How to deal with the addition? ??? Probably missing the forest for the trees. . . . but I had to ask.
The circuit is:
Lo response
Hi response
