I have an ATR-104 4-speed 4-Trk 1/2", 2-Trk 1/4" (w/CTTC head added to output on Ch-3) on which all four Rec/PB amps ceased to work. The machine (transport) powers up, along with the cooling fan on the rear, but none of the amps powers up. I've tensioned tape and the transport works fine, even in remote, using TimeLine Lynx II parallel control / KCU. We've checked main and +5V fuses on the main power supply and the two inside the power supply chassis, all fine. There are four cables (2 large, 2 small) running from the main transport housing up to the amp units. Each of the larger cables connects to a quasi D-Sub multi-pin connector, which leads me to believe they are audio. Each smaller cable contains two wires (therefore, power?) which connect to an automotive-style rectangular plastic connector. Checking those two connector (on the cable end from inside the main transport case) displays low voltage. Has anyone ever had experience with this or a similar situation?
Thank you.
RF
Burbank
Thank you.
RF
Burbank
