Audient ID14 opamps MOD issue
If you really can't find / don't want to find 0603 X7R 100nF/25v caps, sure, I guess a through-hole one is better than none at all.
Well, i couldn't find it easily here,
it seems to be too little in comparison to the original one. Does it matter?
What "seems to be too little"? C176 is 0603-sized (imperial), R179 is 1206, C240 / R180 / R182 are 0805.
Or did you mean the value? Try to remember that i'm "only" human, and i can't read minds. If it's the value you're concerned about, remove and measure C190 (connected to pin 8).
If pin 5 is connected to ground (via a trace on the board), that could mean the second half of that opamp is connected as inverting (positive input to ground).
I think the value can vary, also the size. What would a 47uf do? 1210
C132 seems to be 0603.
    1,020.1 KB
By the way, checked connections again, and 1st pin at first opamp is not connected to anything, I think the trace burnt out. Is there a manual way to connect it with a bare wire. I know is not the right way but which other posible solution is there?
*Picture is before mod.
    598.7 KB
Once again, you're speaking as if i (or anyone else) can read your mind, or know exactly what you mean.
PS. "Continuity test" implies two test points. "Opamp 2 pin 1" is only one.
