I was having a look at the internals of the Audient Sumo and trying to find a way of calibrating this unit so that all 16 channels signal would be equal, as I noticed the signal is not outputting it equally. Some signals were between 0.1db - 0.8db differences.
I am presuming the Component side board is where this issue is happening but it is all resistors, capacitors, ICs, etc.? Am I correct? I was hoping there were like trimpots on each channel so I can adjust the levels.
How would I go about troubleshooting this - would I use a multimeter and touch ground with the negative and on the positive touch a component end on the left side of the board and check what the voltage is? Do I look at the voltage difference and where it is different is where the issue lies?
How does a technician fix the uneveness issue, what usually causes this?
Can I insert trimpots somewhere on this board and make this adjustable?
Does anyone know where I can obtain a service manual for this unit?
(image from kingkorg post)
