Hey guys,
I have an ADR Gemini Easy Rider - its a 1 RU stereo FET compressor...
Its a great sounding little machine - easy to use, goes from smooth to pretty crunchy, super fast attack times... and its got some mojo for sure...
anyway, I am having a pretty weird problem - wanted to see if anyone around here has had anything similar...
the symptoms:
If I run a signal in, say a room mic on the drums, and set the compression for 10db's of reduction in the meter, at some point in between peaks, the meter will drop off...
There is still some compression present, even though it doesn't show any gain reduction on the meter...
At this point, it will rumble/crackle a bit, which will build up until it peaks, which sets off the compressor and then come back in on some successive drum beat...
If I crank up the input gain it will also peak out and sort of reset, work for a bit and then do the same thing all over...
my first thoughts were that it was a leaky cap letting some bad DC thru somewhere, just because of the rumbling/crackling kind of sounds likes a bad coupling cap in a tube circuit...
I had a bunch of the Vishays kicking around, so I swapped all the electrolytics...
There were a few I didn't have on hand, a pair of polystyrene caps and a few film caps - but I noticed the problem a few days before leaving so I didn't have time to get them in...
Then after that I thought it was maybe a bad pot because of how I could sort of pop the compression back in by turning the input and attack knobs...
But I cleaned all the pots and switches as best I could... It has 2 switched pots in each channel - on the ratio knob - you can click it in to 1:1 and use it as a line amp, and on the release knob for an "auto" setting...
After that I thought it might be a badly biased FET, but only because in my 1176's when the FET's aren't set up they just do the weirdest things...
A cold solder does kind if makes sense too... They were genius - the bottom panel comes off so you can access the whole board without removing it from the chassis...
Another odd thing:
If I have it in stereo mode - the meter just mimics channel 1 on the channel 2 led indicator - BUT - channel 1's knobs do not control channel 2 - channel 2's knobs still work...
Not sure if it's related, but it's a bit wired none the less...
I'll attach a copy of the schematic...
I am talking to some ADR gurus on both sides of the pond - but I just wanted to toss it out here too...
thanks guys.
Tim
the symptoms:
Another odd thing:
thanks guys.
Tim
