dukeofearl said:last week i had about 4 channels in and the MC4 module and was able to turn it on and test a few mic pres. couldn't get the program sends to work. i just added a few more channels, turned it on and fried a resistor on the MC4.
does anyone have suggestions on best way to proceed? recap electrolytics and tantalums on every channel before testing further?
I would do that for sure.
Would recap all the channels first
dukeofearl said:would it be possible to bypass the MC4 and entire master section?
Second step, after the recap would be to standalone test each preamp one by one.
Have a simple external PSU, feed the voltages needed. Connect signal at the input and listen for the output.
Does the channel turns on? does it passes sound? Does it sound good?
Next channel and so on
If you could so some measurements it would be great, like Freq Response, noise, etc.
That way you could compare all the channels and see if any channel is not on "Average" with the others.
If you can't do the measurement tests, you have to do listening tests with the channels and see if any of them sounds funny or really different than the others.
If you have a Bench variable PSU with current meter, you can also check the power draw of each channel and see if they are consistent with each other. If you have a channel with an higher current draw than the others, troubleshoot it.
This way when you insert the channels in the console at least you know they are all good.
You can also test the Master section without channels.
