AUDITRONICS 6010 - Schematic Needed
smilan
I just won a bid on eBay on those two Audiotronics 6010 channels.
I would like to rack them and recap the channels and I can't find schematic for those units.
Maybe someone have a copy?
    208.1 KB
    233.3 KB
    278.5 KB
Approx. 10 years ago, I located a service manual for a different Auditronics desk from:
http://www.lightnerelectronics.com/auditronics/
It wasn't a freebie, though....
Bri
Thank you Bri,
I'll send them an email.
If it won't be too expensive I don't mind to pay and save some time... Otherwise I'll track down the supply / audio lines. From looking at the pictures it looks very much like a 110 with more auxiliary sends and maybe some other features.
Maybe the 110s will be a good point to start from.
Unfortunately, Lightner electronics didn't have any info about those channels.
Attached more pictures of the 6010 channels.
One of them have an Allison Research VCA 3 card (I hoe I can run it without the VCA card).
The dimensions of the channels are:
61*3.8*16 (cm) or 24*1.5 *6.2 (Inch)
Any idea from which console they been pulled out?
Since the number of those channel is 6010, they might came from a 600 series?
The only mention of an Auditronix 600 I could find online was at the Grady Gammage Memorial Auditorium which is located in Phoenix, AZ.
There are no pictures of this console, but they described it as a "Auditronics 600 24 inputs, 8 outputs."
Has anyone seen these 600 consoles / have a schematic for it?
Also the VCA card that I have on one of my channels is not a "Transamp Preamp" like the preamp on the 700/701 channels, it might be the VCA module as found on the 701 input module before the stereo bus out?
    1.4 MB
    1.7 MB
    2.3 MB
    1.3 MB
    3.3 MB
    3.2 MB
    3.2 MB
    3.2 MB
    7.2 MB
    7.5 MB
After spending too many hours trying to understand the circuit of the Auditronics 6010 mystery channels with the 86 connections, I was finally managed to make one channel to work and to test it in the studio and damn, it sounds sweet, especially on the low frequencies.
In case someone will get across those channels in the future, attached a list of the pins ID for the 6010 channels:
  • Auditronics 6010 - Sheet1 (1).pdf
    30 KB
