amra
Member
Hello,
I found in a box I've packed long time ago a couple of funky compressor/expander (?) labelled AUSO siemens ELA75-16b, brand new (was packed in the original box) together with several other stuff of the same brand, that I got really long time ago from a dismantled old mastering studio. Inside it uses use several optocouplers, 4/5 big signal transformer and only metallic cased transistors and overall quality of components and assembly looks quite high.
The front panel it's all in italian so I traslate in english the knobs...
The label on tops says "dynamic compressor"
Top one knob is the output level
Just under VU is the input level and under this last one there's 2 section. The one on the left is the xpansor with on/off and threshold and on right the compressor with release and a mode knob that set it as limiter, compressor 2:1 or 3:1.
I try to find any info about these modules but google, kubart doesn't seems to track any information. Today I opened one, carefully find the path of the pinout that I easily track (in/out balanced, +, ground and chassis ground) and carefully applied 12 volt stabilized (since I don't know the supply demand) to see what's happen. Well, at list it doesn't exploded and looks like it turns on
Tonite I will try to apply a signal to see what's happen and possibly how's the sound
If someone is interested I can make some pict of the inside...
Any info about the power supply request of these modules or any other info???
