Nishmaster
Hi gurus,
My bro is doing a bit of his own DIY, putting together a snowmobile from a blank chassis with a bigger engine, more power, etc. The oil tank he has contains a float with a switch that activates a LED to indicate when the oil is low. However, the chassis he has is older and doesn't have this light or space in the harness. I'm going to build one in. The problem is that the power lead from the engine (according to the service manual) is 14.3v AC 10-12A on a single wire from a magneto on the flywheel, and then ground on the other wire. So, I came up with this:
I'm a total noob (well, not total maybe). SW1 is the oil float switch, D1 is half-wave rectification, C1 smoothing, D2 maybe a 12v zener for regulation (probably overkill here, but a pulsating LED from noisy power will annoy me to no end), and of course the resistor and LED. What size cap should I use for smoothing? My big worry is the 10-12A. Is that going to blow diodes, cause general havoc, etc.? Thanks folks.
Matt
![mattyu7.jpg](https://proxy.imagearchive.com/085/085df4c3dc84139476d40a8543ebae9c.jpg)
Matt
