diydidi
Active member
HI Guys.
I'm in the process of building a variable bench power supply. 0-50V @5A.
I have wound the transformer secondary for 0-6-12-22-44 taps. By doing this I can geep the dissipation through the output transistors to a minimum.
I would like to build a circuit that can automatically switch the taps in and out as I advance the voltage pot etc.
Obviously only one relay should be on at any given time, otherwise two of the taps may be shorted. BOOM!!
I will have to power whatever circuit and reference voltage from one of these taps as I don't have space for another auxilary power supply to power this circuit too. I was thinking 4 comparators driving npn transistors, switching 4 relays in and out.
Any ideas? Anyone build something similar before?
