stitch-o
Hey Forum!
I have a 737 that came around with some issues:
Thin distorted input with very very low output signal.
Joe at Avalon has been as helpful as he can be, though (Im sure peeps here know)
I can not get the schematic or any part thereof whatsover...bit of a PITA for servicing.
The Power Supply had given up several transistors and a resistor.
Eventually, I had sent a new one from Joe at Avalon.
With the new PS in, I'm looking at a similar issue:
low output (never above -60dB in PT with all gain up fully), distorted if fully pushed.
Though the low signal is no longer thin sounding..
Issues between mic, line and inst inputs:
with mic disconnected, the noise level is unnoticeable, but when mic connects,
there is a loud hum/buzz. I even had some crosstalk by playing with the preamp gain pot
while line input a 1k tone but selected on mic input.
Instrument input is the cleanest, with very little hum/buzz, but
still very very low output.
At first I thought it was V4 output tube issue,
but now I suspect a power rail issue across the tube daughterboard (3200-7375)
I removed the EQ and comp cards, double checked all tubes with a spare set...still have issue.
I was looking at the 6922 data sheet and noticed that Plate as spec'd is 90-100V (max 220V)
When I tested pin 1 & 6 on each of the 4 tubes, they are at 180V.
Would anyone here know what the plate voltages for tubes in the 737
should be?
Cheers and thanks!
-s
EDIT 1: Hope you all dont mind I use this thread as a talking it out tool...
Found a failed pot: the Preamp Gain dual 25kΩ.
One side seems to have failed and there is a weird pull on the pot shaft when it goes to the
end of the throw. I was chatting with my friend who just repaired an Avalon compressor
and confirmed the pots are not great quality and have failed on his Avalon units.
I'll replace and then diagnose next issue...
should be?
Cheers and thanks!
-s
