Just in case anyone wonders across this and has the same issue as me (No blown fuse but power looping, LED swelling on and off and beeping sound).. I eventually got my broken one working again by replacing both amps (TDA7293) and this diode (30BQ100). I had a bunch of problems, most probably caused by myself, but eventually this is what worked out. Those amp chips are fiddly.. You have to bend them 90 degrees once the legs are through, but its easy to then have the front row of legs folded down shorting to the back row legs soldering points. They come with legs pre bent in a way you don't want, so takes some careful fiddling. I broke a few legs and ended up ordering more amp chips. Hope this helps someone
Sorry for bad picture, I had already put it back together and happened to have taken this one earlier
