salomonander said:
...another option might be to get a solder tip that is shaped in a way that touches all contacts at the same time. weller has tons of funky tips
Sounds like a job for a
Weller soldering gun
Remove the stock tip, replace with solid 10 or 12 gauge copper wire (I use stripped Romex house wire) cut long enough to bend into the desired shape to heat all the pins of whatever, at the same time.
This gun is a simple ~200 turn to 1 turn transformer, with the one turn being a large chrome plated copper pipe that loops once through the core, about a half volt and several hundred amps output. The "tip" is a ~10 gauge copper wire resistor that gets hot really fast, and thus has a voltage gradient, so anything like switch contacts that are closed and connected to two parts of that wire will see some small, but solid voltage, it could destroy the wiper and the contact that is selected.
If the switch doesn't have an off position, perhaps a temporary sliver of mylar tape around the wiper tab, so it doesn't connect? I don't know these switches, and if you can even get to the wiper.
Tin the tip wire with solder all along where you will be using it, heat the pads and add way too much solder to all of them, to make sure they all have good heat transfer, but there will always be that one stubborn one that just won't let go.
I have a dedicated Weller gun with a tip bent and squared off just for dual inline chips, used it just the other day, scored some 8-pin dip 741's.
And no, I don't know why, other than the 741 bin isn't quite full yet.
Gene
