punkt
Active member
- Joined
- Jan 25, 2025
- Messages
- 42
yea already done it, psu voltages seem alright, tube status should be also ok, got a fresh set of new tubes, changed the order, switcherood them, nothing helped, didnt saw any damages, have to get me a new screwdriver kit, because i dont have any fitting bit head for these screws that hold the pcbs.ok.
So if it fails the basic audio test, then we can check psu voltages. It’s been posted where one can do that previously.
If that is ok, then we can confirm tubes status. If tubes are ok.
Then the only thing left is the solid state bits and passive bits. Check for damage visually. Check the pots for damage as well.
At last resort, recap replacing sll
The 10uf and 100uf caps.
Or send it to me and I’ll fix it,
so i will get this and take a look at the tubesocket etc
edit:
ordered an allen wretch set 0,5-3mm and these capacitors, will arrive on wednesday gonna update asap https://www.amazon.de/dp/B0CMQ8XQ4N?ref=ppx_yo2ov_dt_b_fed_asin_title
