Avalon VT 737 sp
Here u go, should i open the PSU ? didnt saw any burned transistors on 5600-737
Orange 11,6
Black 34,6
White 188
Red 34,5
T1 182
T2 ? 6
R34 = 0
R43 41
Yes, open up to give it a visual check. You can pull the connector (3rd pic down) to measure the voltages.
Be careful.
I already pulled the moltex connecter, as i wrote down the messaurements of the connector
Didnt saw any burnmarks in the PSU, but i might be wrong, whats next to check?
    650.6 KB
    355.4 KB
    561 KB
    476.5 KB
    253.1 KB
Thanks for the photos.
From your measurements.
All is fine.
R34 shouldn’t get a measurement. 0v at R34 is correct.
Your voltages sound within tolerance.
Have you replaced tubes yet?
Have you replaced any of the 10uf and 100uf blue capacitors yet?
All is fine.
I already replaced tubes, no i didnt replaced any of them, should i?
are these the right type of capacitors? i think bout 25 of each of them should be enough, let me know if u think otherwise
https://www.mouser.de/ProductDetail/594-2222-036-90109
https://www.mouser.de/ProductDetail/594-MAL214258109E3
thank you for your kindness
Well let’s go back a minute before we do that.
What is the issue exactly?
Can we confirm the unit is passing signal properly?
So the problem is the following, I get only a very thin, very quit output, also its noisy neither the line or mic works properly
Show more photos how you have it connected and how you have it set up as far as the controls.
What do you mean exactly, i need to crank it up on max, max output,max gain, high gain to hear a just little bit
