Avalon vt-737sp
178. 12. +\- 34. 6.29. Pretty much all good. Connected I have the same. Also +\-34 at other suggested points. I see other test points near the preamp gain pot. I just ordered a new set of tubes so that’s next. Will get back to guys end of week when they arrive
You can run the unit with 3 tubes if you don't use the compressor. The other tubes have to be in place though for it pass signal.
From left side of chassis to right it's preamp tube, eq tube, output tube and compressor tube.
Also check the following 5600-7372 card. I think that is the correct card number. it is the one to the left of the PSU chassis. Check it for any failures. recap the 100UF/50V(blue vishay) and 10uF/63V(blue vishay)to extend life of your unit. I usually recap them with Panasonics even though they are not the same footprint, they work well. Come to think of it, that should be done on the eq and compressor cards too.
I see a T1 on the I/0 board. Should I be getting a reading there. No voltage detected there. I have +/-34 and 14 volts on those top two resistors but really don’t. Know what to test for on that board. Caps were reading high uf when connected but good taken off board.
K. Tubes arrived and still no signal. My 6volts was still giving problem. Fluctuating but tinkering around d4 and r11. I think the circuit board pads might be a little suspect. Maybe a cold solder but after tinkering now I have a solid 6.29-6.30. But still no signal. Starting to think that it’s also the i/o card but only see one test point. It reads 0 volts. I get the +/- 34 and 14 volts at those two resistors on top that are always mentioned. The caps and transistors seem to test ok. Only think I saw was when testing caps in circuit they tested high uf. Off the board they tested good.
Hmmmmm.
T1 is most likely for dc offset and uses the trim pot. You should see some signal there unless it was trimmed flat as it should be.
If we test solder point t1, t2 and the others on the main board in reference to ground, what do you get?
I will try again tomorrow. But this morning it was T1 179v. T2 6.2v T3 .0056v T4 69v
I marked up some photos when I worked on one of these units a while back. Hope they are some use to you for tracing input signal once the power rails are sorted.
    1.7 MB
    1.3 MB
K. Thanks again. They were reading high in circuit. But off they were testing good. I will try again Friday. Thanks for your help. I will test those points tomorrow
No voltages at any of those test points. I get 93v on those orange caps in the middle two points. The outer two points read 0v. The bottom one reads 100v on the right side and a negative small reading on the left. I’ve read on prior posts about replays going bad. Where are those located
This is the underside. Should I be reading any voltages at those test points. Maybe TheseGoEleven has a larger pic
No. Those pots were definitely put in. In fact it is pushing up on the vu adjustment pot. Gonna replace those after unit is working. I see someone wrote that it was worked on in 2021. All of this was the way I got it
Here is a larger pic of the underside. The vertical board that houses the push buttons for "high gain", "phase", etc will send a +12V DC or 0V signal to the corresponding relays via the colored wires. I don't remember which wire color matches with each button but you can find out by experimenting.
    2.7 MB
Yup definitely not like mine. K will rest in a bit again. But I think I couldn’t get any voltages from any of those T points
