Dear all,
Thanks to your precious help I believe the regulator now works pretty fine!
In the schematic attached you can see that I substituted one 100V zener with an 82V zener and used an 18k resistor to obtain the right regulating current. Also, I bypassed R2.
Now the ripple is gone for good!
The only little concern I have is the power dissipated by the mosfet which is around 6.3W (I~260mA)
The heat exchanger gets quite hot - around 70C - so I might consider to add R3 again to dissipate some of that power.
Other than that, do you have any other suggestions to improve performance and/or reduce part count/footprint?
Thanks again!
Fabrizio
