B- voltage for tube preamp
Potato Cakes
Nashville, TN
Hello, everyone,
Earlier this year I acquired a pair of Collins 356B-1 program amps that I was trying to wire up before I headed back out on tour. In the original manual, it shows a "B-" for one of the connector pins, which I have never seen. For the voltage requirements, it just says voltage is 250-300 volts DC and 6.3 volts AC or DC. I was referencing some other tube preamp designs and it seems that what the Collins schematic refers to as B- is tied to ground through a resistor. Would the connection labeled B- just be tied to ground? I don't see anywhere else in this specific circuit where the tubes have any ground reference connection of any sort.
Paul
  • Collins 356B-1 Schematic.pdf
    103.1 KB
B+ is the HT voltage and B- is it 0V reference. B+ and B- are a left over from the days of battery power when the terminals were marked _+and -. Note tha in this module the heaters are completely isolated from the HT supply. Somewhere, usually back in the external power supply, the heaters would be directly or indirectly referenced to B-.
I don't see any path B- to ground.
B- connects to Amplifier Common. B+ goes to the usual places. Put your 300V battery across B+ and B-. Put your 6V supply at 6V screws. Connect ground (chassis, not amplifier) to your rack and general dirty ground system.
All audio in and out are transformer, floating.
As Ian says, "somewhere" the 300V, 6V, and dirty ground come together. Usually at a power supply. However the amplifier WILL work with an un-grounded 300V battery or isolated power supply. The tubes do not need to "see ground", they just need to feel both ends of a 300V supply. Possible increased hum and lightning-risk due to no path to room ground or heater supply, which is why we normally bond A B and chassis somewhere.
PRR,
Sorry, what I was trying to say is that what is called B- on the Collins schematic is connected to a ground reference on other tubes designs that I compared to this one. B- is indeed not connected to ground in the 356B schematic.
Paul
Ground is a very ambiguous term. The B- on the schematic you posted is connected to signal 0V. There are various 'earth'  symbols on the same diagram and these will refer to the chassis.
Thanks for clearing that up! It'll be a couple of weeks before I source the case and a couple of other parts to put this all together. I'll post some pics when it's done.
Paul
Just a quick update on this project. I finally got a case for it, but I'm lacking a number of switches and some other small parts. These modules are very big and they just seem to fit while allowing enough room to do all the wiring. Hopefully one more mouser order and I'll be set.
    524.7 KB
