HI all,
I've finally got my BA-6A functioning but with one little hiccup. The meter is reading a 10 on the GR scale at rest and I cannot get it to zero. Its a Simpson Model 27 0-200uADC. I've read that the original BA-6A used a 0-500uADC meter, but should that affect the zeroing? I've also read that making careless mistakes with these (expensive) meters can be regrettable. My meter circuit matches the attached schematic. Increasing the zero pot value increases the problem, and jumper-ing the 82 ohm resistor has no effect. The screw on the front of the meter does very little. I've read a bit about shunting these meters when they are mis-matched to the circuit, but I don't think I understand properly how to do it. The unit has little to no noise/hum in the audio path and seems to compress properly.
Any help zeroing the meter would be appreciated. Would increasing the value of the 82R resistor be effective/safe?
All the best
All the best
