jstark
Hey y'all.
Wiring up a Soundtracs Megas that I just picked up.
The manual for my Crown DC-300a shows to wire the input as follows:
I'm really confused as to why you would ever attach the Cold line to the sleeve of the TS...
Are they assuming that you would tie the Cold to the Sleeve at the source, as in Figure 5 of this http://www.rane.com/note110.html document?
(if it helps, the output of the Megas that I'm using is a ground-compensated output...)
David
David
