Baldwin Discoverer tuning pot
dukeofearl
this is not a very common keyboard and i can't seem to find a schematic. when i got it, it was out of tune and i located the tuning pot inside (the silver thing with blue and red stripes). i had no trouble tuning it with an allen wrench. now it's out of tune again and it won't turn at all. must be really soft plastic that stripped because i didn't use much force at all.
anyone have any idea where to find a part like this without a schematic? or a more robust replacement? thanks!
    695.1 KB
You don't need to replace it with the same exact part. Just usolder it, measure it and then look in Mouser, DigiKey or similar for a trimmer of same value and similar footprint.
You could even replace it with a standard pot wired with leads and install it on the rear panel for immediate access, although I don't think it is necessary.
That looks more like an IF style coil or transformer than it does a trimmer pot?
Many keyboards of that era (mid 70s pre MIDI) used a top octave synthesizer chip - like the MK50240 - to act as a master tone generator.
That technique would require a master oscillator that ran at around 2MHz, and often used either a crystal or a hi stab LC oscillator for tuning accuracy.
Sounds like you may have an LC master oscillator here?....
Without a schematic or part number it's going to be difficult to match that coil/transformer precisely.
What you could probably do is find the ferrite core slug from a similar sized device and replace that.
(As already described, you're going to need a non ferrous trimmer tool to tune it.)
When I say 'similar', you may find the core from an IF transformer will do the job? You can find those on Ebay.
(Typical UK source HERE - I'm sure there are similar US sites?... )
i think this might be beyond my capabilities and i ought to take it to a professional. or put it in the closet and not think about it.
