Recently acquired a Peavey AMR 800 24 channel 8 buss, Split console w/ 16 tape monitor returns, Full LED Meter bridge, Rack Power Supply .
Am in the process of pulling channel strips/ monitor/ master section and tape return modules for cleaning and inspection.
Overall its a very clean console, save for a thin layer of grime on the top which is easily coming off.
The modules PCBs look like they just came from the factory ! Faders while being the cheap Junk poon Korea brand are still functioning for now
Not bad for a 34 yr old console.
Questions for those who know these mixers :
Apprently some or all of the pots and switches were custom made per this model ? Who made them ?
Where were the knobs sourced from ? Am considering changing the style / color scheme.
Meter Bridge LEDs were sourced from ? In case any are burn out.
Since my AMR 800 appears to have been built in June of 1990 (based on the handwritten inspection stickers with names and dates on each PCB channel strip) I am presuming it has the Junk Poon 10k faders. What fader law are these using, Logarithmic? I need to start sourcing replacements so they are on hand if /when the Junks fail.
The meter board rotates back for servicing, its hinge adds some support for all modules or vis a vers. Since the hinge does not tie into the side cheeks I am considering adding a small diameter metal strut to further strengthen the sides. There is enough clearance when the meter bridge is rotated into position to do this. This will also keep the cheeks from pressing in on the meter bridge as its a very tight fit between them.. Reason is I may have to store the mainframe (empty or full) for a while standing up on one end and dont want the frame to tweak out of square. There shouldnt be an weird electronic interference with being close to the meter bridge pcb ?
At the 'rear' end of the channel PCB, nearest the inputs, Red 4 pin connectors are labeled in groups of 8, being numbered 1 thru 8 on the connectors as opposed to 1 thru 24. Any reason for this?
After pulling channel #16, I noticed the last 8 channels 17 thru 24 are not connected via the individual red 4 pin connector - one per channel from the cable loom running along the tray near the rear inputs. Pic is showing the cables w/ red connectors that plug into the 4 pin conn on pcb shown here on channel 9
Cables from this run connect to each channel module 1-thru 16 . However those cables w/connectors are missing for channels #17 thru 24. The schematic/block diagram says it - conn labeled as J112 - feeds the"Monitor" section ?
I've read some older Gearspace and GroupDIY posts etc about swapping ICs out for more modern ones. Seems the general thinking is there wouldnt be much of an improvement, if any ? Seems kinda subjective. Someone also opin'ed that a 2 stage preamp design would have been better but my own jury is still out on that one.
Finally, from my ever adventurous mind, Was wondering how hard it would be to incorporate several channels from a different console ? Swapping out 2 or 4 of the AMRs channel modules for a higher end strip from say an API, Neve, or any other top quality console. if the incoming channel strip is a close fit physically with minimal fabrication and if its power needs can use the AMR PS 19v + - voltage and seamlessly rout into the AMR busses and master section. .
Of course, its easy to say 'just use outboard racked channel strip etc instead', But am thinking to make the console more unique and custom to my studio.
The overall condition of this AMR 800 is really excellent, PCBs and all parts look brand new for a 34 yr old mixer. But anticipate some recapping.. Once she is up and running for a few days, we'll do a more in depth check.
In the late 1980s into the early 90s Peavey created a separate division called AMR- Audio Media Research, attempting to break into higher end market and make their name known for pro quality $10k to $20k range consoles. They didnt succeed no doubt due to their name being more associated with lower end gear, some say customers would see the "Peavey " badge and walk away. Also the profit margin for mid to high range pro consoles is not great so ole Hartley canned the product range. Yet these consoles are a sleeper, being very well designed. A number of small and regional studios are still operating AMR 32 and 36 trk consoles to this day. The cult following these have, its reputation for fairly 'clean' preamps and versatile Eq plus the myriad of ins/ outs routing along with nice layout and ease of access maintenance makes this console range a keeper.
Appreciate any help per all the questions especially from John Roberts if active here in the group.
