frazzman
Gustav said:frazzman said:I know man.... But my backwards logic is that I don't want to bust my chops on these monster 6 pole switches if the main board is cooked
I've checked all the -/+ 18v on the opamp sockets... Can you recall if there any other docs that reference other voltages on the board ? Otherwise I might have to unrack my dual mono unit and start comparing.
With no switches and pots, you have open input pins on quite a few opamps. I would have made sure to analyse the circuit or at put in dummy loads if it was beyond my capability. If nothing else, just to make sure I wouldn't be driving an opamp death somewhere
Looking at the schematic on the bands, I am having a hard time figuring out how you are passing audio at all with no switches or pots installed, but I am not a wizard![]()
Your safe bet is to apply the dummy resistors as Ruairi suggested, if you want to see how it behaves before wasting time doing switches and pots.
Gustav
Hi Gustav,
Yes, you a right. I think it's my methodology which is a bit nonsensical. I did build one unit successfully with a few hiccups along the way.
I guess my aim was to tackle it in blocks but realistically that's not a very logical approach. I could easily sub in resistors as dummy pots, I probably should have considered that earlier.
Anyhow thanks for the feedback. It's onto the switches now. This is an epic build, it's easy to want to try to dissect it into logical stages.
