jplebre
- Joined
- Nov 3, 2012
- Messages
- 617
dagoose said:Just wondering what would be the benefit of the lowpass filter (LC) on the input.
only thing I can think of is if it's set to something like 20Hz for mp3 encoding but...
Keeping RF out.dagoose said:Just wondering what would be the benefit of the lowpass filter (LC) on the input.
Operating range of this EQ limited between >0Hz ... 20Hz would make this EQ useless.jplebre said:only thing I can think of is if it's set to something like 20Hz for mp3 encoding but...
protools said:Blue is a must! Just to honour the man.... Barry Porter.
Thanks! Didn't really check the frequency myself, i'm bad at math but my guess was something like 100khz. It's way higher then I expected it to be. 8)Harpo said:Keeping RF out.dagoose said:Just wondering what would be the benefit of the lowpass filter (LC) on the input.
This is a L/C filter, cutoff is @ 1/(2*PI() * SQRT(L*C)) with L in Henry and C in Farad.
With given values 30uH for the common mode choke and 100pF for the caps, this LFP is set @ 2.9MHz.
..as well as P12a/P12b.skal1 said:R , i see it now, p9-a and p9-b is a dual pot yes.
Keep P6a/P6b and P15a/P15b or substitute with 2 deck switched resistors for the peaking LF and HF bands.skal1 said:harpo if i do not want to use the shelf , could i leave P6a/P6b/P6c and P15a/P15b/P15c ?, this will make the frequency 2 deck yes.
skal1 said:so i thing ithe best thing for me to do is research about the most useable frequency for a mastering eq.
ruairioflaherty said:The original Porter layout is double sided, not very home etch friendly. There were gerbers only.
Harpo said:but FI the law bending 1K5 resistors (R114,115,111,112,...) at the CCW end of the frequency pots will then be one side connected, doing nothing, when the pots get substituted with the switched string of series resistors. The calc sheet is based on listed values in the calc sheet, so if you FI keep the series resistors (R87,61,83,58,..., these are in parallel to prementioned law benders, connecting to virtual ground and 0V reference voltage, and already part of the series string at the switches), the filters center frequency will be different (FI the previous 2kHz-20kHz range would respond for a 1.528kHz-4.896kHz range instead when you keep the 3K6 resistors R61 and R87 instead of using 0Rs/shorts).
You are mixing up Barry's schematic and parts values (using a 10k lin pot and 2 resistors in a Wye-config) with my adaption for a single stepped series resistor.Nescafe said:When keeping (R114,115,111,112) and also (R87,61,83,58) the full CW is right:
1/(2*PI()*SQRT((3600)*22E-08*(3600)*22E-08)) = 20095.32
But I don't understand how to calculate the R value in the middle and in the full CCW![]()
