Hi guys,
I'd like to build a neat compact A/D-Converter with ADAT out based on the Wavefront pair AL1101 (A/D) / AL1401 (OPTOGEN), as used by Behringer in the ADA8000. I have disassembled an ADA8000 and looked at the schematics to it, to get everything right. I have experiences with analogue preamp sections and I'm aware of the function from A/D, but it's the first time for me to (re)build somthing with a clock distribution. So there are some questions to it:
This device (as many others) has four clock operations:
1. Master 44.1kHz (derived from the first internal XTAL with 11,2896MHz, labeled "CLK11")
2. Master 48kHz (derived from the 2nd internal XTAL with 12,288MHz, labeled "CLK12")
3. Slave ADAT IN (output from the AL1402 with internal PLL is labeled "OPTCLK", the sync lock-indication, lowactive, is labeled "OPTLOCK")
4. Slave Wordclock IN (output from the PLL (?) 4046 is labeled "PLLCLK", the sync lock-indication, lowactive, is labeled "PLLLOCK")
So far, so good.
All CLK-Signals lead to an 74HC153 @ "MUXB", pin 10-13 (CLK11 / CLK12 / OPTCLK / PLLCLK). The Sync-lock-indications lead to the same chip @ "MUXB", pin 5+6, 3+4 clamped to 5V. There are two signals from the clock-operation switch to that chip, "SELA" & "SELB", that are lowactive when Slave-wordclock or slave-ADAT is selected, that makes sense.
My questions aim to what happens on the outside of the 74HC153:
- @2Y, output of MUXB are two 74HC393 in series. The 2nd outputs the CLK-Signal "ULRCLK".
But: CLK11 & CLK12 are in MHz range and OPTCLK / PLLCLK are 44.1/48kHz, right? Don't the two 74HC393 divide the 256x fs MHz-Signals down to 1x fs? Aren't then the 44.1kHz / 48kHz Signals then divided down, too?
- @1Y, output of MUXA is the Signal "CLKLOCK".
- ULRCLK runs through two schmitt triggers (74HC132) in series, the first is bound to the CLKLOCK Signal from 1Y, the output is "LRCLK"
So, with the PLL-function: ULRCLK is distributed to the 4046 (for WC IN) and the AG1402 (ADATIN) as the reference-signal, because the aim is to resync the external CLK to the received data, but ULRCLK is derived from PLLCLK (in case of WC IN is active), so the only phase shift to be compensated is the one generated from the 74HC153 and the two 74HC393 in series, or not?
Then another thing: in my A/D-Project, there won't be an OPTOREC (AL1402). In the schematic of the ADA8000 the OPTLOCK-Signal from it is used to unlock the schmitt-triggers to distribute the internal clocks CLK11 and CLK12, too, although they don't have to be checked, if they're synchronised to anything, is that right? So, if there isn't any AL1402 in my plans, isn't is just possible to switch a "lock"-indicator with the switch that sets clock-operation (WC IN-option is in my project, so the schmitt triggers blocking unlocked signals make sense)?
Am I right, or far out?
Greetz,
wilma
So far, so good.
Greetz,
wilma
