Matador said:By default, the polarization supply is 120V to match the B+ line. The backplate of the capsule is 60V (taken from a resistor divider), and the front capsule is grounded. Hence you have for polarization voltages:
0V = omni mode
60V = cardioid mode
120V = figure 8 mode
Since the stock supply has a 9-position switch, there are 6 extra patterns between those above. Starting at omni mode, each click of the switch raises the polarization roughly 15V.
Thank you,
in this case the stock PSU has the B+ at 200V,
I measured the B+ in the mic and I have 180V.
So how would it be in this case? 180V for the figure of 8 pattern?
