Dear Dual flip?
That horrible (noisy?) TL07x has roughly 3 uV of input noise. That is down over 100dB below nominal line levels. If you can hear the TL07x input noise you are using it wrong (at too much closed loop gain). Good design practice is to not use TL07x at more than 20dB gain because it runs out of loop gain margin (I like to insure 20dB of loop gain margin at all audio frequencies).
Of course in the 4+ decades since these parts were introduced better technology is now available. I'd be surprised if they stopped improving. :
If I was still active in the mass market design trenches I'd probably have new different go to candidates for low and high impedance sockets. Design engineering for large scale manufacturing involves cost vs. benefit. For one-off DIY projects use whatever you are comfortable paying for.
As I already shared I recently used a $4 dual CMOS opamp- AD8656ARZ in a one-off design. A remarkable part for 5V rail use. If I was designing for mass production would done this differently.
I would lower expectations for huge audible differences from swapping out TL07x/NE553x from competent (older?) designs. Prior to those better than audio op amps being widely available in the mid 70s the typical op amps were more like 0.5V/uSec slew rates.
PS: I am willing to share the one or two sockets were modern parts could make a measurable (not necessarily audible) improvement to my older big console designs. If you own one of my old production series consoles just ask. 8)
