Which is why no decent design engineer would use a TL07x for a summing amp. :
I actually used an NE5534 as mic preamp in my DJ mixer kit (1978) but that was intended for high Z mics. The NE5534 calculates out to a 9dB NF (noise figure) with a low Z mic, so again a poor choice for low Z mic preamps.
Phono preamps are less obvious (I have design too many phono preamps to list them all). If you inspect the Bode plot (open loop gain) of TL07x op amps, we will see a falling gain plot caused by the internal compensation pole. Then compare that to the RIAA EQ curve, RIAA is ballpark 40dB gain at 1kHz (60dB at 20Hz) but falls off to only 20dB gain at 20kHz, so actually usable (while I never have). If you inspect how noise sources combine to influence noise floors in gear you will find it dominated by early gain stages. Of course high noise gain circuits like VE sum amps with a lot of inputs benefits from modern low ein devices. I can criticize weaknesses in both but back in the 70s they were a godsend for audio designers. These days we have more options. I am trying to offer perspective... adding a 3 uV noise stage in an audio path with existing noise floor already tens of dB higher noise will be barely measurable, and unlikely to be audible. I am too lazy to do the math but hint it involves square root of sum of squares.
