Duizels
- Joined
- May 1, 2016
- Messages
- 55
Hello,
The past weeks I've been lurking around here (and elsewhere) soaking up knowledge. I've been home recording for years and recently built a first DIY mic kit. It has gotten my super excited about the subject and I love to learn more, build more own mics.
But I'm blessed with a creative brain (I paint and design) and maths is like dyslexia for me. My knowledge of electricity is zero. I've started reading books like this but it quickly gets too complex or mathematical for me https://www.ibiblio.org/kuphaldt/electricCircuits/ I've read somewhere here that its never too late to learn so here goes. I like to understand this and learn...
I wanted to post some questions here, and get a thread going to give me a basic understanding of how everything works in a condenser microphone, so when I eventually build another mic (kit or self) that I can understand what I am doing, instead of "paint by numbers"... I appreciate your time for helping me come to grips with this materials!
My first questions are based around the T12 kit from microphone parts, based on the Neumann KM84 circuit. The signal path is described as JFET > Output Cap > Transformer.
So if I understand correctly, phantom power is sent from the XLR pins (which ones?) through the circuit, to put a constant charge on the capsule. Sound pressure makes the membrane move, causing a varying voltage sent out from the capsule. The first "station" now is the JFET correct? From what I have read the JFET sounds like being a "gate or valve" allowing more or less voltage to go through? But what is its function? Because the diaphragm already sends varying voltage out?
The next stage is the Output Cap. From what I read online this serves the purpose of "filtering", allowing sound? to move through but not DC? I read it removes noise? My lack of electricity/audio understanding really makes this hard to grasp. This component also colors the sound? I read that depending on the material it gives clean or warm/thin/colored transfer of the sound.
The last in the signal chain is the Transformer. Is this simply to boost up the incoming signal to a "loud" enough source to record? Or is its function different? Again I also read that this part heavily influences the sound of a microphone?
Because of my lack of understanding of electricity, I am confused about what is Voltage, Current and DC? And which is of these is the "sound" and which is not? When I read things like "this part blocks DC" to me it pictures in my mind like different streams of water, the electricity (DC?) is blocked but the sound is allowed to pass through ? Probably I am getting this TOTALLY wrong haha I feel such a n00b.
regards!
regards!
