Behringer B1 condenser mic schematics anyone?
Moby (or any),
Please post if you do anything else with this. I bought that and a couple C2s for cheap here recently and would be interested to see what you do to it. From the brief listening I did with mine, I didn't mind the brightness so much as the self noise it seemed to have (I believe it was with a Symetrix 528 pre at the time). Some pretty loud low frequency junk was going on between words, but I'd have to check it in a more "sterile" environment. It could have just been picking up more machine/ambient noise.
I'd also be interested to know if any of the people here have suspects in some of the common B-1 failure reports you can find online. It's usually stuff like "mic started making loud rustling noises & pops after a while, got worse, and is now unusable". If it's possibly something other than the capsule, it would be cool to swap in some better replacement parts just for the peace of mind.
BTW- Any ideas on what would be expected from the aforementioned Peluso capsule,etc.? I don't have a large selection here (4050,RE20, various other dynamics), and was sort of looking to get something with that "Chinese bite", but lower noise or higher reliability might be worth adding a few dollars to it.
George
The poping noises are usually dirt on the capsule - note that it happens only when you sing(or play) into the mic.
try to clean it with cotton and distiled water.(very gently!and only if you think you can do it without destroying the capsule..)
i just mounted the capsule from the B1 in a G7 mic with an oep transformer wired in series - that takes a bit of the brightnes off.i like the result.very usable.much better then the MK319 capsule.
now waiting on a peluso capsule...
    319.7 KB
    303.5 KB
    378.1 KB
Could you please share clear photos of both PCBs? I’m struggling to understand the schematics because I’m completely inexperienced. I was attempting to replace the capacitors in my Behringer device, but nearly all the wires detached from the PCBs in the process.
Hi guys, could anybody send pictures of how wires are connected from capsule to the pcb? I’m not able to read the schematic right now
I managed to take relevant pictures
The Red and Orange wires come from the capsule
I posted the schematic earlier.
    3.1 MB
    2.6 MB
    3.2 MB
    3.2 MB
    3.5 MB
What were you hoping to achieve by changing the capacitors?
The microphone is built by the famous company 797, it has a good schematic, a copy of the Neumann tlm103, the components are of quality, the capsule is good, the specifications are good.
If on some sound sources it can be brighter, this can be solved during processing, with eq.
Huge thanks! I bought it used and later discovered that the capsule was damaged (it didn’t pass the breath test). I replaced it with a Chinese RK-87 copy, but I wasn’t happy with the sound, so I decided to experiment with a capacitor swap to try and improve it. Heard that capacitor change could change the mic sound a little bit.
I just received an NT1 5th Gen, so I’m not too worried about the B-1 anymore, but I still need to get it fixed.
Thanks again!
Thanks again!
OK, I'm glad I could help you. I've studied the B1 and B2-PRO a lot. They're good microphones, if you know what to do with them.
The Chinese RK-87 needs some deemphasis to sound more balanced.
The 797 stock capsule from the B1, put it in a sealed bag with a few silica gel packets and leave it for a while, maybe you can save it.
