Bendix c213300 output transformer
Pretty low inductance, so don't expect low end unless it's an amp circuit with enough feedback to lower drive Z significantly. Someone else can do the math on drive Z to be reasonably flat at 100/50/25/etc
Just taking some quick measurements with my Fluke 8060A
Across 1&3
1k@ 6.14VAC--- .000048 Amps
100HZ @ 6.07VAC--- .000179 Amps
That seems a bit different..better at least....... guess I'll recheck... should there be less inductance at higher frequencies? Sorry for my ignorance....
Not sure why different test has a different result.. maybe straight up reading w/cheapy meter isn't as valid??
Am I supposed to have the transformer secondaries connected to a load? This is without them being connected...
    971.7 KB
Your lcr meter only test at 1Khz. And probably with a low signal level. No wonder you got low readings. Yes, higher test frequencies result in lower inductance readings.
Try the test cj suggest with 50Hz or 60Hz. Depending on where your dmm is most sensitive.
Inductance is just a resistance with J operators, so Ohms Law applies,
so you just go
1 K Hz: 14 V-ac / 0.000048 = 291, 667 Ohms (XL)
100 Hz: 6 V-ac / 0.000179 = 33,520 Ohms (XL)
XL = 2 pi f L we want L, so isolate the term L,
L = XL / 2 pi f
i get 46 and 53 H which indicates a gapped core,
I like the "Out-Put" part, never seen that,
Yeah me bad, 20 H, no gap, need laptop, not phone, and some bi focals! And maybe some speed balls,
So figure about 70 H at 20 hz.
Run that thing all day at 100 hz and watch the Henrys go up to 100 if it has not been plugged in for 50 or 70 years.
