CJ
just a quickie on this cute xfmr,
sec was open, so we dissect,
Pri: 1.2 Henries @ 5 Hz 5 Henries @ 20 Hz, 3.1 @ 100 and 0.64 @ 1 Khz,
DCR Pri: 48 ohms,
these things are Not DIY friendly, and a real PITA to take apart,
the mu cans are pressed together tight, so you have to cut off the back of the larger can and hope for the best,
the lams are 1 piece with two sections of bobbin glued around the middle leg, ....did i say middle leg? ;D
anyway Beavis, they then put a wheel up next to the bobbin and spin on the wire, this makes for an ultra low leakage, high inductance (for their size) xfmr, which is what you want in a small mic input,
so the coil is a real pain to remove, you have to cut and file mu metal, which is always fun,
DCR Pri: 48 ohms,
