BGW750 G power amp has PS warning LED on.
CalavoBob
La Mesa, CA
I've got a BGW750G power amp in my shop which has a power supply warning LED that goes on as soon as the amp is powered up. I have a schematic for the B and C models but not the G. Both power rails (+ and -) are a solid textbook 85VDC with about 110 mVpp of sawtooth squeaking through on top of the massive 21,000 uF caps that follow the rectifier bridge when the output is connected to two dummy 8 ohm resistors with no signal applied. There's 780 uV of noise on the left and 900 uV on the right, mostly random hiss, but there's a little 60 Hz in that noise floor. I've removed both amp boards to check them;, but have not found problems with the banks of power or driver transistors, and the few electrolytic on the boards measure fine with no leakage as do the handful of tantalums.
This got me suspecting the board with the warning LEDs but nothing obviously wrong there either. The electrolytics on this board tested ok. There is an LM339 that is used to make that PS warning LED work.They're an obsolete comparator chip and I've seen these go bad in other gear; but usually the LEDs they drive just go dark. I've got an RS339 in my parts bins that I'm considering replacing it with but I'm not positive that it's the same thing as a LM339. I thought I ask the forum if anyone has seem this problem before.
It actually seems to work well with no audible distortion or noise and I'm getting what appears to be the rated power on my test bench. It's just that the pesky power supply warning LED stays on. I think I'll try to replace that LM339 with the RS339 chip that I have here.
Comparators are not that complicated, measure the voltages at the two input pins and the output and see if the behavior indicates a working or non-working comparator. Maybe you are just glossing over what you have checked on the warning circuit, but it almost sounds like you are going to replace the comparator without even checking the circuit to see if the output of the circuit makes sense based on the input voltages.
339 comparator circuits are (or should be ) pretty simple to troubleshoot.
the 339 uses what's called an open collector output. So when the + input is higher than the - input commanding a "high" output state, the output transistor is turned off resulting in a high impedance output.
When the + input is lower than the - input the output is in an active "low" state, which means the output transistor is turned on pulling the output down to the negative supply.
To illuminate a LED the cathode could be connected to the active low output and the anode through a resistor to the + rail. Of course there are other ways to use that open collector output to light LEDs.
This is a good circuit to learn troubleshooting on.
Of course do no harm, don't blow up your working power amp trying to fix a PS light.
The LM339 has a few variants and equivalents and should be relatively easy to find. Some of the variants have different tolerances so sometimes those with hi spec variants are suitable in SOME circuits but to simply put an LED on in an amp like this should not need a 'rare' (close tolerance) part. The open collector design means that you can use 2 (or more) comparator stages to then light ONE lamp (LED) so you may have one comparator 'looking ' for a positive DC offset, and a second 'looking' for a negative DC offset.
It doesn't look like the LM339 is obsolete.
https://eu.mouser.com/ProductDetail/Texas-Instruments/LM339N?qs=rshUhwi3fbY%2BaR%2BOl3edNw==
I didn't even check, because I ASSumed the OP was correct about the LM339 being discontinued. Mouser USA shows 10s of thousands in PDIP.
https://www.mouser.com/c/semiconductors/amplifier-ics/analog-comparators/?q=lm339&mounting style=Through Hole&package / case=PDIP-14&instock=y
I did find a RS339 at Digikey, but it was in a SOIC package AND limited to 5V power rails.
Bri
It could also be something as simple as a crusty IC socket, if the chip is socketed. I was using 750G's in 1980, so that amp is no spring chicken.
Assuming the attached schematic is accurate, these comparators are configured to respond to AC level coming in through capacitors C403 and C303. The LM339 comparators respond to DC inputs so are biased +/- one diode drop above and below V/2. So in proper operation at rest with no audio playing the LEDs should be dark and light when AC level exceeds the diode drop thresholds. So the first obvious suspects are either C303 or C403 capacitor leaking and presenting DC to the comparator input.
With a VOM carefully measure all of the LM339 input pins to determine valid output states. Since these comparator outputs are connected together in pairs, if either comparator is commanding output low the common output will be low and the LED illuminated. If the LM339 outputs do not agree with the input states the LM339 may be faulty.
Those seem likely to be the clipping indicators.
There is a note that "for the 750G, 9008-0763 display is used, see drawing 9600-0763 for detail" and this post is concerning the 750G.
Since there are no LEDs labeled for the PS indicators, my first assumption would be that circuitry is on the noted 9600-0763 drawing.
Thanks to @moamps for the BGW750G schematic and parts layout. That gave part numbers and voltages I needed. It showed a reference voltage at the comparator inputs 4 & 7 of 5V but I was getting 0V there. It is derived from the B+ which is good and goes through D325 and a 1M resistor which also were good as were the 10uF cap and 1M resistor they bias up. The only things left that could kill the 5V are the 2 paralleled comparator inputs. So I replaced the LM339 after all, and the dreaded power supply fault LED went out. Thanks to all of you in the forum who generously commented. Case closed.
Just curious.....did you use the RS339 that you had on hand?
Bri
