BIG SALE: studio gear and parts
salomonander
lots of stuff:
- original v-series mini rack for 4x v72 200€
- studer vertical vu meter 60€
- military mic amp (no schematics) with haufe transformers. stuffed pcb no case. 150€
- old tube mini micpre-limiter (no schematics) 150€
- 32ch ntp metering system for vga monitor 250€
- haufe st4294 a 30€
- high quality eo illuminated switched non latching in red a 8€
- itt high quality rotary switches 4x5 - these feel like elmas but are much smaller - solder lugs  a 15€
- sperpent audio sa3a high quality front plate SOLD
- 24v volt power supply by siemens in eurorack 100€
- grayhill 1x8 pcb version adj stops a 8€
- grayhill 1x12 solder lug adj stops (budged version)  a 7€
- bruel&kjaer tube mic stereo set. no power supply - untested 300€
- gefell power supply for mv691 plus cables 80€
- 4x20 lemo patchbay soldered to siemens messerleiste 160€
- audio teknik studio multicore with stagebox. 24ch 150€
- telefunken ef86 NOS a 40€
- telefunken ef804 NOS a 40€
- mwl/wilag original bottle mic no power supply 2000€
- neumann/mwl m7 bajonett prototype 500€
- neumann mv2 mic splitter 150€
- ua audio la2a input transformer 250€
- ilok with cla compressor license 200€
- roland jv2080 including hip hop extension 170€
- emu esi 4000 100€
- telefunken/siemens v97 tape amp 250€
- marconi isolating transformer in sweet bbc boc 120€
- marconi matching transformer in sweet bbc boc 120€
hi,
are these :
4pole 5 position?
thank you
zero said:
hi,
are these :
4pole 5 position?
thank you
exactly. 4 poles 5 psotitons. if you want more than 5 i can give you a discount. cheers
salomonander said:
zero said:
hi,
are these :
4pole 5 position?
thank you
just two more question, what´s the contact material and plating?
Do the contact make before breaking?
thank you
best regrads,
Pedro
zero said:
salomonander said:
zero said:
hi,
are these :
4pole 5 position?
thank you
thank you
best regrads,
Pedro
looks like gold. im not sure if they make before break. how do i find out?
hi,
if you can see the contacts check if that in between two positions the pole touches both contacts or shorts with a multimeter.
best regards,
Pedro
zero said:
hi,
best regards,
Pedro
no beep on my multimeter between the poles. so i assume non-shorting... cheers
salomonander said:
zero said:
hi,
best regards,
Pedro
Sorry for the delay and the hassle but i really need shorting type, sorry.
thank you.
best regards,
Pedro
