Hi all,
This is what's making me crazy today: I built a 2-channel N*ve 1272-type preamp with Carnhill transformers and Joe Malone's 1272-to-1073 boards. I have switched phantom power hooked up to both inputs, one channel is fine, the other one gives me 2.5V on pin 2 and 0V on pin 3 of the xlr. There is 48 volts before the 6.81k resistors on both channels and both channels are wired exactly the same way. Yet one channel passes the phantom to the input connector and one doesn't. Both channels of the preamp seem to work fine with a dynamic mic, sound good and sound the same, and measure the same distortion and noise. Could this have something to do with the primary of the input transformer? I'm baffled. Any ideas?
Thanks.
:sad:
Thanks.
:sad:
