Blindtest: what does a micparts V47 sound against a vintage U47?
md431
New member
Germany
Hi guys,
I recently built two micparts V47, one with RK-47 capsule and one with a Mikrofonunion M7 STW7 (red line). I had the chance to record them with two vintage U47s, from which I've made an audio blind test. This is part of a project I'm doing at University of Applied Sciences Darmstadt.
If you're interested, you can find it here: https://www.soscisurvey.de/mythosU47/
There is also a Schoeps Mk4 included for reference and a DIY Fet47 (Vamisound, Moby, micparts RK47) thrown in for fun.
If you partake, please use good headphones or monitors, as the differences can be subtle. It takes about 20 mins and it really helps me out if you pull through to the end.
Please take this endeavour with a few grains of salt:
  • These kind of shootouts never fully represent real life studio practice. You tend to figure out where one mic sounds best and then hop to the next to compare. It all comes down to room, placement, source in the end. Here, all are recorded from the same position (as close as possible) on the same take. Take it more like: This could be an indication of the results you could get in your scenario.
  • My main priority was to get comparable takes, meaning it had to be the exact same performance. Therefore all mics are set up close by eachother, this will have some impact through reflections and absorptions from adjacent mic chassis. I tried to keep this impact similar for all mics where I could.
  • This blind test is not (and never was) meant to produce definitive statements as "DIY kits are better than vintage mics" or else. For the project, I'm mainly interested in the differences people can hear in this setup and how the listening experience matches up with the expectations.
  • All vintage U47s have aged different, are serviced different, sometimes are built different and therefore sound different. These are just some examples of what one might get. Your previous experience might vary.
  • All was done under immense time constraints and in retrospect I'd certainly have adjusted a few things here and there. If I had known the mess I'd get myself into, I might have chosen a completely different focus alltogether..
Nevertheless I thought it might be interesting to you. Not to get definitive answers, rather an impression. Or best, to have some fun :)
I've tried to include a good variety of recording situations (two sets of drums, double bass, vocals, acoustic guitar).
I measured all mics in an anechoic chamber too, using Neumann KH120 speakers, an FourAudio ANT motorized turntable and REW. This again is not to make statements on how these mics perform, rather as an additional, technical data set. If of interest, I can share these frequency responses and polar patterns once done.
PS: please don't tear me to shreds. I'm new and still learning.
@Barry Hufker thanks for the kind words.
Also thanks to those who took the blind test so far! Every participiant helps me out tremendously as this is a rather niche subject. On a different note: I loved the Vamisound PCB and micparts builds and the listening results so far are very favourable of some of them. Will definitely do more as soon as the funds have recovered..
Just did the test, which was a fun listening exercise. But it takes long - more like 40 mins - so beware. Surprised that I picked the Townsend as my favorite over all.
@ElSmurf I got mixed feedback regarding the time it takes, depending on how people choose to listen. thanks for letting me know and many thanks for taking the time!
@jazzcrisis it's super interesting, the rankings go all over the place. Some have a strong perference for the Townsend, others for the micparts K47 and others for the Telefunken U47. Those seem to be favoured at the moment, but funnily the Fet47 get's a fair bit of love too.
Yes please.
Have you got a measurement of the KH120 speakers with an accurate measurement mike too? eg B&K 4133 or simlar?
What distance did you measure the 'K47s' at? This is CRITICAL for Cardioids like '47' type mikes and also Fig 8 and other directional mikes.
Yes, I measured the KH120 in the chamber with an ISEM EMX7150. I set up the factory calibration file that came with the ISEM mic in REW and sweeped the KH120s. I then used that measurement to set up a calibration file for the rest of the following measurements. Also set up calibration to compensate for any effect caused by the soundcard, this was done beforehand. The internal SPL-reading was first matched with an external SPL meter too.
The mics were all set up with the capsule at level of the bigger speaker in the KH120, roughly 1.4m height and at 1.5m distance. The speakers and microphones backs were aprox. 80cm from the "wall". All deflection cones in the room measured about 60-80cm. The room size is aprox. 3m length x 2m width x 3m height with the mesh flooring 50cm suspended above the "floor".
I measured at 85, 90 and 95dB at 0° and at 85dB and 7° increments for the polar pattern, both for omni and cardioid. I used 2.7s long sine sweeps.
Unfortunately the anechoic chamber is relatively small, so there are some anomalies going on, namely +3dB at 107Hz and -2dB at 145Hz. I can confirm this, as I have one "professional" measurement for one of the original U47s to compare to. Why the bumps popped up after calibration is a mystery to me, but my best explanation so far are reflections/modes from the room.
As I'm writing this, I'm realizing it may be because the size of the microphone chassis, as the bumps didn't pick up on the Schoeps MK4 (tiny) and ISEM measurement mic (also tiny) but over all "big" mics consistently, in both cardioid and omni setting.
