I found a very cheap TG113 speaker with FM radio for the building site , the first one broke at the USB charge point within a few days , then I found another different one ,
Ive now ended cobbling up a single two way speaker from the parts ,
I was able to add a second drive unit to an empty slot in one of the enclosures , I connected them both in parrallel across the amp terminals ,
One speaker was very trebley the other a touch bassy , the combination of the two is surprisingly good .
It seems to work best pointed away .
I added a better FM aerial which made a huge difference to reception quality .
The downside its everytime you power the unit up it defaults to bluetooth mode , which is announced by a Chinese lady at full volume .
Its a PCB of this type or in any case it uses the same chip ,
I wonder is there a way of reprogramming the firmware to change the voice .
https://www.rytronics.in/product/tg113-bluetooth-speaker-circuit-board-module/
