Quint24 said:Hey guys. Here's and update on the converter. Currently it's boosting to approx 30V constant. This is with a 5W load and the output current is very low 0.13A. I require 1A. When I put a 50W 30 ohm load on it, the output voltage fluctuates like crazy well below the desired value. I can't figure out why this is happening, any ideas?
It may well be noisy because you effectively have a 'rats' nest ' layout. Can you probe the fet gate-source terminals at the device using a probe with short ground pin , and taking a single shot waveform capture.Quint24 said:Hey guys. That was the waveform to the gate, it's quite noisy when it's connected to the load, I never took pics though. Will do that on Monday.
While modern electrolytics are better than they were, you may also need a HF cap (like ceramic disc or film) in parallel.Quint24 said:Hey Abbey. I had a 100uF cap between the supply and group just before the inductor, is that big enough or should it be larger?
I can't see it on the picture. It must be VERY close to the inductor and the FET's source. I'm not sure 100uF is enough, depends on the construction, and, as JR suggests, it may take advantage of a ceramic capacitor of at least 0.1uF.Quint24 said:Hey Abbey. I had a 100uF cap between the supply and group just before the inductor, is that big enough or should it be larger?
