MagnetoSound
Check that C14 and C28 aren’t leaky.
You should probably install D4 as well, for reliable control.
Checked Q1, Q2, Q3 and C2, all of them okayDid you check the polarity of C2, - to emitter Q1, + to R4 C3 junction.
C14 and C28 are okayCheck that C14 and C28 aren’t leaky.
That may have been removed for the power supply modCheck that C14 and C28 aren’t leaky.
Yep, that's how I narrowed down the noise to a couple of areas.Are you using a scope on the signal path?
So at what point does the level drop in bypass? What are you using as a test signal?Yep, that's how I narrowed down the noise to a couple of areas.
I re-installed the other chips, I get no effect at all and the sound is the same in bypass or when engaged.
I'm running out of time this week to work on the pedal but will report back soon!So at what point does the level drop in bypass? What are you using as a test signal?
