BOSS DI-1 ... looking for schematic
clintrubber
The Netherlands
I'm looking for the circuit schematic of that still going BOSS DI-1
Anyone got ? Or traced it ? Perhaps even the Service Notes ? (these are for sale I know, but I'm first of all curious to what just the circuit is like)
  Peter
Allow me a bump. There's one for sale here and was wondering if its circuitry is more sophisticated than the usual EU30 alternatives.
This DI-1 has been around forever already, so likely someone had a peak inside already ? Or user experiences with one of these ?
  Peter
I only traced it partly years ago (missing the attenuator stuff) and have some hand-drawn notes.
It consists of a Fet-Buffer (with a 2SK246-GR) similar to the Boss FA-1, and outout buffer (with a 2SC732) for unbal. output and an balancing circuit with a M5218.
It can be powered by phantom-power, the supply voltage is catched with two resistors, diode and stabilized with a zener-diode.
Depending on the price, but I would choose the Behringer GI-100 (Ultra-G).
analogguru
Hi analogguru,
Thanks for responding & the info.
Aha, so nothing special, no compound buffering, just straight on single
device stages. No need to go specifically for this then. The suggested Beh. indeed a better
route, at least you get fresh caps  ;)
Have another box upcoming, will be replacing the guts.
Bye/thanks,
  Peter
If you get hold of a Boss DI-1 I would be interested in pictures of the guts to finish the partly schematic I drew uo during a service job.  I had not enough time for an exact schematic.
analogguru
It would only be my personal choice, because:
1.) it costs only EUR 30,-- / I don´t know the price of the Boss DI-1
2.) it is galvanically isolated (transformer balanced) / the DI-1 is electronically balanced
3.) it has a (not so bad) built in speaker simulator / the DI-1 doesn´t have this.
The only thing I dislike is the TL064 used inside, but I think this is a problem caused by the abilty to get the supply voltage from the phantom power.
analogguru
oh, thanks
nice to know that
What I was not getting was if you mentioned the Behringer to use as a DIY project or if someone simply needs to buy a cheap and reliable DI box.
regards
TS
analogguru
I won't be getting the DI-1 for sale here but I'' keep it in mind to post here if the schematic or a tracing opportunity ever pops up.
Bye,
  Peter
regards
TS
To bypass mechanical-DIY:
I just made a Thomann order and while at it I threw in their cheapest DI, to be used for the enclosure.
Before I remove the guts I'll have a listen to it stock though, otherwise the original circuit (a single cheap TX I expect)
will never have seen a signal  ;)
http://www.thomann.de/nl/millenium_die_dibox_passiv.htm
Bye,
  Peter
Whoops said:
Nice Box,
its cheaper than buying the Box + switch + jacks and XLR's in separate!
Well done,
I feel sorry for that cheap transformer.
It's a good box for DI I think, there are also a couple of internal standoffs that can be used to fasten a small PCB to. These are now used to clamp the TX to the case. No idea about the TX and its ratio (box came 'specless') but I might measure a bit before I 're-populate' it.
Bye,
  Peter
No idea how bad that '6'-range actually is. Seen it indeed in more DI-boxes. An opamp (say a dual) that can work well from phantom, it's indeed a universal issue: low-enough power & decent audio quality. We might start a poll on what people think would be the best type for that application.
Bye,
 Peter
I found a schematic for the Boss DI-1 after acquiring a couple of these for almost nothing (http://www.hh.iij4u.or.jp/~tokumi/pict/di-1.GIF).
The housing is quite nice. The circuit is pretty ordinary. It's a simple FET input stage with a M5128 dual op amp buffer. The op amp is about as good as a 741 op amp, so I think the best thing to do is to rip out the guts and design a new board that will pop in to replace the old one, with improved noise and response specs.
