CJ
picked up another Weller mag switcher on evilbay for fifty smackers , man, i love these things, when i opened up the box i had to take a leak, ;D that's how excited i was,
well, if you suffered with thermistor junk and crappy tips at work all your life, wtf, over?
tips will last decades, not years or months if you treat them right and don't use them for pry bars,
meant for commercial use so they do not mind being left on,
magnet inside tip gets hot and loses magnetism after reaching Curie temperature which releases spring loaded breaker, when it cools, magnetism returns and pulls in breaker for more heat, you can hear it clicking away as you work,
nice silicone cord does not tangle like black cords,
they still make tips which has an alloy at the base manufactured for a specific Curie temperature for attracting the magnet,
one problem is the newer tips have shrunk in diameter a bit and will not be retained by the barrel,
so either get a new barrel of NOS tips ,
heat range is controlled by the tip, numbers are stamped on the bottom, usually 6,7 or 8.
7 is the way to go.
if you ever get tired of shelling out for tips then im jus sayin...
here is a cool site with some history>
http://www.stevenjohnson.com/soldering/history.htm
7 is the way to go.
