broken neumann usm 69
allinbang
Member
Hello everyone :)
unfortenatly I know very little about electronics, so any help is appreciated :) I have a Neumann USM69 microphone, which does not work - at first, only one of the capsules (or sides) was working and now, nothing works, it just has a continous noise on both channels and if I shift patterns is has a loud noise. At one point I took the top part, which has the capsules, off and it was the same noise (don´t know if I shoulden´t have done that?) I hope it just a question of some resistors, capacitors and not the capsules themselves (as I expect that would be very expensive) - I have no illusion that i can troubleshoot this my self but maybe someone in here has had experience with this ? maybe someone in here has a schematics for the USM69 ? then I would at least be able to take it to someone that REALLY knows how to fix this. Any help is GREATLY appreciated and I apologize for my ignorance :)
Allin
My 2 cents is to try and fix it yourself, it already doesn't work so you can't really make it worse then not working. Well you can but it would have to be like I drove a screwdriver through the capsule ;)
