Snatchman
Hello..It seems I remember this vendor had this product at one time..I'm trying to convert a single input 8 pin op-amp to a DOA style socket. ( plug and play)..Is there a socket available now..? Thanks..
Oh, that is funny! I was picturing it the other way around - Put a DOA into a DIP socket
" Put a DOA into a DIP socket"Oh, that is funny! I was picturing it the other way around - Put a DOA into a DIP socket
I have done so with some perfboard, a wire wrap DIP socket and millmax pin receptacles. Ugly, but it
aaaaand 13 years later they no longer appear to sell them, however, I found these:Actually dug out my homebrew adapter and realized I used SIP headers, not a wire wrap socket. The overall board is smaller than a 2520. If you only need one or two it's not a bad way to go. I just needed one for a prototype. Otherwise the Analog Classics boards are a no-brainer!
I tried there and could not locate the 2520-style adapter with the offset +/- pins. I'll probably just use some breadboarding as above.
