stickjam
The Hammond hot-rod project continues...
I've abandoned the idea of replacing the solid state Leslie 770 amp with a 122-style design for a number of reasons, so I'm turning my attention to adding the grit within the organ itself.
At the best point to insert this "color" stage, it scopes out at a nominal 1.1Vpp unbalanced signal. The new circuit's output will be seeing a 20K impedance. I hope to model the same balanced topology of the Leslie 122 amp in a lower-power line version. I am envisioning the signal chain of this stage being:
Attenuation -> DRV134 to balance -> 2-stage balanced tube amp based on the 122 -> iron to unbalance -> Attenuation
One design objective I have is to implement the user interface not as separate drive and output controls but as a single "Brown" knob. (I'm actually considering being cute and using a decorative knob from a toaster that has different shades of "doneness" painted onto it. :green: ) I'd like this stage to be a psychoacoustically-if-not-electrically unity gain device. With all else equal, the apparent volume shouldn't change when you turn the knob--just the color should change.
My questions are:
1. Am I going to need to add some more gain on the drive side?
2. I originally planned to use a dual-gang rotary switch and hand-selected resistors as the "brown" knob. I'd ideally like to make it more of a smooth performance control rather than having discrete steps. Is there any way a dual ganged pot could be configured to provide the intended behavior? Will I need some exotic forward+reverse combo taper thing?
3. Any suggestions on what tube type (lower power pentode) and transformer model I should use to get a line-level output that imparts color most like the 122's 6550 power amp stage?
I'm getting close to completion on the power supply (hoping 300V 30mA B+ is sufficient). I'm looking for ideas as I prepare my shopping list for my next visit to the local "toob shop" for supplies to breadboard this piece.
Bob
My questions are:
Bob
